ok so i ahve a 91 Z24 whcih for some reason has a base cavalier gauge cluster in it
i grabbed a Z24 cluster from the yard but the JY cluster only has 205kms where as the 1 from the car has 280kms is there away to remove the 2 odomoters and switch htem so the 280km is in the Z24 cluster? i got a carfax report done and teh 280km is the correct reading
ohh ya i guess i wasnt payin attention and pulled a gauge cluster from a 92+ with ABS so the stupid ABS light stays lit constantly,i jsut pulled the bulb out for the ABS,is that fine?
FDP 62MM TB, FFP Performance Chip, FFP Underdrive Pully, WAI, Hi Flow Cat, 2.5" Catback, Functional Ram Air Hood, Centerforce Dual Friction Clutch
I set my Sunbird Odometer back to zero when I built the engine.
It is not just poossible... it's downright easy..
Cardomain|
Myspace
you should be able to swap them out, as I did it with mine a few years back.
well i was gonna swap them but the base clsuter didnt ahve a trip odo. so i rolled the kms forward on the 205xxx cluster
M I N I O N - Sinbird wrote:I set my Sunbird Odometer back to zero when I built the engine.
illegal what?
R.I.P. Brian St.Germain
MS Walk April 21 - I HIT MY GOAL!!! thanks to those of you who have supported me!
^^^^^ I wasn't aware it was illegal to tamper the milage on an unregistered, untagged drag vehicle. Better start cuffing the people with nothing but a tach mounted to their roll cages!
Cardomain|
Myspace
ahh...see, you didn't specify, and since MOST of the people on this forum are doing things to their DAILY DRIVERS, it's easy to assume that it's a legal vehicle.
specify next time, will you? not all of us know what everyone else on the forum owns and drives.
you can roll the kms back if you take off the clear plastic part.
Removing the ABS bulb is fine. The 90-91 didnt have that feature. In fact I found a 92 cluster for my 91 at the time. I put bulbs in all the empty slots and the ABS was lit. Its my belief that the bulb is grounded completing the circuit and harms nothing.
