not starting! need help!!!! - Second Generation Forum
Saturday, November 05, 2005 9:29 AM
ok so heres what happens, i turn the key to the on position and all of the power works(cd player, neons, gauges etc.) but then when i turn the key over to the start position all of it cust off, and nothing happens. engine doesnt make a noise, doesnt turn over at all. and all of the power inside (gauges etc.) shuts off as well. wtf???
its not the battery, it has a good charge and a jump start wont do anything (already tried)
i need help ASAP so if any can be given i appriciate it!
-94Custom
http://www.personal.psu.edu/users/a/t/atl126/ricers1.gif
Re: not starting! need help!!!!
Saturday, November 05, 2005 10:34 AM
OK
That's a classic sign of a bad connection-when the starter tries to draw lots of amps to operate it drops all of the volts at the bad connection,
It could be at either end of:-
the positive cable ( Battery or Starter)
The Negative cable (Battery or the chassis grounding point)
A bad connection will get warm to the touch if you try to start for a long time.
In your case it looks as if the bad connection kills everything before you have time to get it warm.
Try all these points by disconnecting the battery and then removing, inspecting and cleaning all four points, clean the chassi where the earth cable connects..
This assumes the battery and the starter are OK
Hope this helps
Alont
Saturday, November 05, 2005 5:55 PM
its the chassis ground i had the same thing happen to me a year back.
Sunday, November 06, 2005 8:11 AM
its either a bad connection for the power somewhere or a bad starter
Sunday, November 06, 2005 8:30 AM
allright i went out last night and bought a new starter, and that was the problem. thankx for the help guys! she purrs once more!
-94Custom
Sunday, November 06, 2005 12:46 PM
I'm glad to hear you found your problem. ^_^
