will a 2.2 crank work in a 2.0? If so will the pistons from the 2.0 work with it? Will it make a difference?
Cause I have forged pistons for a 2.0 and if itll work and and make a difference Ill do it when I rebuild my motor if not I wont mess with the 2.2 crank.
The OHC and OHV engines are different. The OHV crank is not compatible with the OHC block. There is a 2.2L OHC engine that's related to the Pontiac. It's used in Isuzu Amigas. But I've read that the block is taller, which means that you may or may not be able to find rods and pistons to allow that crank to work in a stock height block.
-->Slow
