So i have gathered up a "shopping list" of what all i believe i will need to complete my Eco-swap. If you have anything on the list let me know.
I also need an 00-02 Graphite dash core, 00-02 Graphite Dash pad, and 00-02 Trim Bezel. Possibly a Steering column.
Shopping List
• fuel rail
• fuel lines
• Upper engine mount bracket (The part that bolts to the motor.)
• J-body Eco oil pan
• Lower mount bracket (Where the dogbone bolts to on the motor.)
• transmission mounts
• J-body power steering pump (off of an LD9 or L61.)
• intake cam
• oil dipstick
• oil dipstick tube
• all cooling lines
• evap line
• cruise control throttle cable
• Ecotec radiator
• Ecotec Upper radiator hose
• Ecotec wiring Harness with Cruise control and ABS
• Auto Ecotec ECU
• Ecotec front Axles
• Auto Transmission/ transmission case as well
Edited 1 time(s). Last edited Tuesday, May 18, 2010 12:27 PM
Sunfire Interior Swap! Do it!
There is a blue eco sunfire in harry's at pennsburg..still has both cams, radiator, oil pan, auto trans w/ mounts, motor mounts...the motor is basically complete except for the valve cover, ecu and a few hoses that I pulled...if you go now you can pretty much do one stop shopping.
drew get at me i got some parts i found in wayne's box of parts.
i have fuel rail,,fuel line,,upper mount,,oil pan,,and intake cam....i believe thats all
I have the oil pan
Mods: Synapse Charge Piping, Short Throw, Bad-Mab Dp, Dejon Intake, BYT Tuned!
Parts For SALE! Pacesetter Header(ECO),17'in Resonator, Alternator, Starter, Viper Alarm.
I have...
All the radiator hoses..
Might have the engine mount bracket, will have to dig
Lower mount bracket, yup
Rubber fuel lines and hard lines that attach to the engine
All the Evap lines and Purge solenoid
Power steering pump and reservoir
Also have a ton of @!#$... A/c compressor, and other odds n ends I never trashed yet.
$25 bucks, just come pick it all up. I will literally hand you boxes of ecotec @!#$.
Thanks to all for letting me know what you got. I will let you all now later in the week when payment comes.
Heres an update for eveyone who has parts.
Shopping List
• fuel rail
Have
• fuel lines
Have
Have upper part, still need part that bolts to the block
Have
Have
Have
• intake cam
Have
• oil dipstick
• oil dipstick tube
• all cooling lines
Have
• evap line
• Ecotec radiator
Have
Have
• Auto Ecotec ECU
Have
Have
dont forget u have all the ac lines now too
whoos the man i am
