I have a 2000 Sunfire, was in a wreck and needs striaghtening....the door is gapped about an inch or so from where its supposed to be at the top rear corner...
The rocker panel pushed back into itself if that makes any sence? I would post pics, but have no way to right now. So, I am going to try and explain to the best of my ability.
The peice that goes under the lip where the fender bolts up, goes to the top mounting point for the top door hindge and all that that has the spot weld and can be replaced or coarse is fine. I need the bottom part pulled where the bottom hindge bolts, and the rocker area...
If you can help, let me know ASAP and a rough estemate on how much you would want to fix it for me.
Thanks!
"Hondas are like tampons, every pussy has one!!!"
