I'm looking to get rid of some parts. All are from an 03. Most I won't ship due to needing the stock replacements. Shipping is extra.
RK Sport upper motor mount - $50
Carcustoms lower motor mount - $20 + your stock one
reveco throttlebody - $100 + your stock one
custom rear strut tower brace - $50
spare ecotec head, no cams - $50
Comp Cams - never installed! $300
Street /Strip 113300 set 113301 INT/113302 EXH ) GRIND # ECO XE258HR-11
Grind Specs 8760/8761 HR111
INT
Max Gross Lift: .440
Cam Lobe Lift: .260
Advertised Duration: 258
Duration @ 0.50 Valve Lift: 216
Valve Timing @
0.50 Valve Lift: BTDC: -2
BBDC: 41
EXH
Max Gross Lift: .436
Cam Lobe Lift: 258
Advertised Duration: 262
Duration @ 0.50 Valve Lift: 218
Valve Timing @
0.50 Valve Lift: ATDC: -3
ABDC: 38
2 12" Kenwood Tornados in a single box. Don't know the specifications. $75
http://www.cardomain.com/ride/676422/1
PM sent
![](http://i59.photobucket.com/albums/g302/joeydabomb/Sigs/joeysig3.jpg)
what kind of gains from that specific cam..i would like to get something more aggressive than my supercharged cams i have..seeing im not supercharged
Built&Boosted moar
honestly, I don't know. I never installed them. You'd have to ask someone more knowledgable on cams than I. Comp Cams does say tuning is needed with these cams tho.
ss/sc injectors still available? any pix?
![](http://i179.photobucket.com/albums/w317/05xtremecav/rebernx5.gif)
231.6whp
still have th upper mount?
i got a stock lower mount if u wanna trad anything for anything else
Kill list:03 eclipse, 06 GTO, 04 Mach 1 Mustang
are you still in Milford? if you still have the TB in a week or two i might have to swing by and do a little swap with ya. when i can get down that way
Is the eco head still available? It would have to be shipped to me.
Edited 1 time(s). Last edited Thursday, August 28, 2008 4:43 AM
aaah. i already told you i wanted both mounts! lemmie know when you wanna swap.
loving the mounts man thanks a lot.vibrations are only bad when it's cold and idling. btw, do you know what brand they are?
id take the tb off your hands if you didnt need a core
im interested in some of the parts you have like throttle body and cams my number is 317-306-1217
