Audiobahn System FOR SALE - Mid East Region Forum
Thursday, October 04, 2007 10:31 PM
I'm selling the system out of my car for $650. If you are interested or have any questions, please let me know. All the specs are listed for the subs, amp, and head unit.
2 12" Audiobahn AW1208T Flame-Q subs with metal paintable flamed grill covers in custom built box.
1 Audiobahn A2150HCT High Current Flame-Q 2-Channel Amp with Remote Mount Bass Boost Control
1 Pioneer DEH-P6600 Head Unit with detachable face and remote control
SPECS:
Audiobahn AW1208T Subs
Features
* Optimized for Maximum SPL Ported Enclosures
* PHAT 2” Multi-layer Foam Surround
* 280 oz. Magnet
* Stamped and Balanced Aluminum Cone
* 6 mm Thick Cast Flame Basket
* Multi-Connect Lug-Lock Terminals
* Mounting Depth: 6 3/4”
* Hole Cutout: 10 7/8”
* Outer Diameter: 12 1/2”
Subwoofer Specifications
* Size: 12"
* Rec. Sealed Box Dims: Not Recommended
* Rec. Ported Box Dims: 1.30 - 3.15 cu. ft.
* Free Air Usage: Not Recommended
* Sensitivity: 91 dB
* Frequency Response: 20-500 Hz
* Recommended RMS Power: 1500W
* Peak Power Handling: 3000W
* Impedance: Dual 2 Ohms
Audiobahn A2150HCT Amp
Features
* High Current Circuitry
* 1-Ohm Stable: 1200W Into A 1-Ohm Load
* PWM MOSFET Power Supply
* Double-Sided Glass Epoxy Circuit Board
* Variable Parametric Bass Boost
* Remote Bass Control with Blue Backlight Knob
* Variable 24 dB High & Low-Pass Crossovers
* Variable Subsonic Filter (20-45 Hz)
* 4-Way Protection Circuitry
* Cobalt Blue Illumination
* Blue LED Voltage and Status LEDs
* VU Meters Indicating Output Response
* Secondary Flame-Style Heat Sink
* High Gloss Chrome-Plated Finish
* Nickel-Plated Block Terminals
* Dual Fan Cooled
2-Channel Amp Specifications
* Amplifier Type: 2-Channel
* RMS Power @ 4 Ohms: 150W x 2
* THD at 4-Ohm RMS Power: 0.05%
* Bridged RMS Power @ 4 Ohms: 300W x 1
* Speaker Level Inputs: No
* Preamp Outputs: Yes
* Built-In Crossovers: HP/LP
* Bass Boost: 0 - 18 dB
* Frequency Response: 10-20,000 Hz
* Signal to Noise Ratio: >100 dB
* Supertuner IIID (AM/FM Radio)
* 24-Station/6-Button (18FM/6AM) Presets
* BSM (Best Stations Memory)
* 1-bit D/A Converter: 16-bit
* CD-R/CD-RW Compatible
* AGC (Automatic Gain Control)
* Disc Title Memory
* CD Text
* Additional System Expandability
* IP-Bus System Control
* Multi-CD Control
* DVD Control
* TV Tuner Control
* Built-in Auxiliary Input: CD-RB10 or CD-RB20 required
* External Unit Control: 2
* Display Type: Organic EL (OEL)
* Dot Matrix OEL Size: 128x32 + 24x32 (Blue + White)
* Screensaver Movies: 2 (Air Show, Lost Shipwreck)
* Background Animations: 4
* Level Indicators: 2
* Built-in Speaker Power: MOSFET 50W x 4
* Equalizer: EEQ (3-Band Parametric)
* Equalizer Presets: 5
* User Equalizer Settings: 2
* Sound Focus EQ
* EQ-EX
* Loudness: 3 Mode
* Electronic Balance/Fader
* Source Level Adjuster (SLA)
* Crossover Network: Two-Way Crossover
* High-Pass Crossover (HPF): 50/80/125Hz, -12dB/Oct.
* Subwoofer Crossover (LPF): 50/80/125Hz, -18dB/Oct., +/-12dB
* RCA Preouts: 3 pair (Front, Rear, Sub/Non-Fading)
* Preout Voltage & Impedance: 2V, 100 Ohm
* Remote Control: Card
* Wired Remote Input
* Cellular Mute
* Detachable Face Security
* Face Case (Included)
Re: Audiobahn System FOR SALE
Thursday, October 25, 2007 9:19 AM
No takers, huh?
