ok when i floor my car and it hits about 5200 rpm, it sounds like its leaning out....any cure?
What do you mean, it "sounds" like it's leaning out? The only way I know of.....
Get a WBo2 and check your afr's
or
Get a scangauge and check your injector pw
2000 Camaro V6.
| SLP Loudmouth | CAI Intake | HID's |
well once it hits 5200 rpms it sounds like the pistons are topping out or there is too much fuel in the mix...sounds like preignition to me
2000 Redlined wrote:well once it hits 5200 rpms it sounds like the pistons are topping out or there is too much fuel in the mix...sounds like preignition to me
You have a 2200.   You're past the powerband.
Install a header.  This will probably move it up to around 5600-5800 before it happens.
thanks, im wantinto get the pacesetter anyway
