Yep I'm selling the gixxer. I have some plans in the works and don't need it anymore. She by no means is a perfect bike and right know is having a ignition issue. I have put several thousand dollars into her and have recipts for all the parts I have replaced. With all that in mind I want to get her sold so I'm going to sell her for $2,000 as is. More if I get to fixing the ignition problem. Let me know
SPEC's
Engine: 749 cc, 4-stroke, four-cylinder, liquid-cooled, DOHC, 16-valve, TSCC. 118 hp (86.1 kW)/ 11.500 rpm, 78,5 Nm/ 9.000 rpm.
Bore x Stroke: 72.0 x 46.0mm
Compression ratio: 11.8:1
Carburetor: Mikuni BDSR38SS x4
Lubrication: Wet sump
Ignition: Digital/Transistorized
Starter System: Electric
Transmission: 6-speed constant mesh
Flnal Drive: RK50MF0Z1 Chain
Overall Length: 2055mm (80.9 in.)
Overall Width: 720mm (28.3 in.)
Overall Height: 1135mm (44.7 in.)
Seat Height: 830mm (32.7 in.)
Ground Clearance: 130mm (5.1 in.)
Wheelbase: 1400mm (55.1 in.)
Dry Weight: 179kg (395 lbs.)
Suspension: Front: Inverted telescopic, coil spring, adjustable spring preload, rebound damping, and compression damping, 43mm stanchions
Rear: Link-type, gas/oil damped, adjustable penske spring preload, rebound damping, and compression damping
Brakes: Front: 320mm dual hydraulic disc
Rear: 220mm single hydraulic disc
Tires: Front: 120/70 ZR-17
Rear: 190/50 ZR-17
Fuel Tank Capacity: 18.0 liters (4.8 gal.)
Exhust: Yoshimura slip on.
Quote: no ofence man but if you have so much experience in all that why does your car look like crap?
