air cylinders - South East Region Forum
air cylinders
Tuesday, April 25, 2006 7:56 PM
I have a bad slap in my rear air cylinders like they are bottoming out constantly because I have to run such a high pressure to get my car high enough off the ground if anyone has a solution to my problem please help maybe some longer bottom rear brackets i dont know
Re: air cylinders
Wednesday, April 26, 2006 11:22 AM
Hey what pressure is the rear lifting at? Do you have the 3.25" Cylinders in th rear? If so it chould only take 55PSI max to lift, if its taking more than that then somethings not right. Slapping? your riding with too much presuure, lift it tillthe cylinders max then just dump it a TINY bit, thump the swich. Have any other problems let meknow
xxtazchazzxx@aol.com
