2.4l engine swap - Performance Forum
2.4l engine swap
Wednesday, June 16, 2010 2:23 PM
Just swap 2000 2.4l into a 98 cavalier that had a 2.4l in it but the check engine lite is on b/c the knock senor on the car has one wire and the new motor has two wires. Is there a way the i can fix this.
Re: 2.4l engine swap
Wednesday, June 16, 2010 2:34 PM
yes, i hate to say it but you'll need to drill the knock sensor hole larger and then tap it for the bigger thread.
or.. weld a nut to the block that has the right thread. up to you.
180hp in 1989 or 145hp in 2002, you decide. >
Wednesday, June 16, 2010 3:57 PM
still dont follow but the knock sensor on the new motor has two wires and knock sensor on the old motor has one
Wednesday, June 16, 2010 3:59 PM
the one with (2) wires is the 96-98 style and older. it just happens to be larger.
the one with (1) single wire is the 99-02 style and newer. it actually has a smaller bolt that holds it on.
you have a 98 so you need the older (2) wire style.
Wednesday, June 16, 2010 4:16 PM
its two different knock sensors... that are two different sizes... the block has a smaller hole on the 00+ and a larger hole on the pre99
i had to use a helicoil to make a 97 block work in my 2000... you have to drill the block out
you can't swap the knock sensors over, the 98 computer will not read the 2000 sensor...
