Hey all, I need some tech help here. I have a 97 Cavi that is a short track car. The current short block is toasted, I have read that 98's have a different piston that when combined with a 97 head will rasie the compression. Does anyone have any numbers as far as piston volume, head cc etc.?
Also will a barebones 98 2.2 shortblock interchange into a 97 car with all 97 long block parts? Keep in mind this is not a daily driver, I can fabricate things, Dont care about emissions, can wire, and can edit PCM's. I just want to make sure the interchange is correct.
Any insight at all would be great, thanks. Ryan
Owner - LS Solutions.GM EFI tuning and controls fabrication.
Pro-Touring 71 Olds Cutlass, 364" LSx - 440rwhp - 11.55 @ 117 - 1.69s 60' - 22mpg - 3,850lbs
Short Track 97 Cavalier, massaged 2.2 and tweaked ECM
