2.4 Injectors - Performance Forum
2.4 Injectors
Monday, March 09, 2009 9:07 AM
Hi, all !
Has anyone replaced injectors on a 2.4 ? If so did you go stock or aftermarket ? Also which brand ?
Thanks
Re: 2.4 Injectors
Monday, March 09, 2009 9:23 AM
Most go aftermarket, since they typically want bigger injectors to support increased power output.
The injectors from the LSJ (Cobalt SS/SC) work with the 2.4L connectors. The only thing that needs to be done is the fuel rail's bolt holes drilled/dremel'd out to accomodate the shorter length of the injectors. You want the fuel rail sits lower, basically.
Stock are around 24lb/hr flow rate. Stock LSJ injectors are 36lb and you can obtain them for around $30-50 over on the CobaltSS.net classifieds. You can also use their "stage" upgrade injectors, such as the 42lb/hr injectors that you can find on there in the classifieds for $100-150.
2001 Olds Alero (LD9)
636 whp / 543 ft-lb
@turboalero
Re: 2.4 Injectors
Monday, March 09, 2009 9:55 PM
If you run the cobalt injectors will it make a diffrence if untuned?
bc97cavalier
