i was just bored one day playing with design concepts in google sketch up.
has any one tried to modify a mid-engine in a j-body im just curious and don't be a hater im not talking a v8 v6 im just curious is it possible and what kinda cash would it take
i have a 89 subaru justy with a 1.2l 3cyl (like 75 hp) the dimentions are perfect
nuts bolts wiring are not the issue
i would neeed to remove the rear seat and cut out a portion of the floor get longer @!#$ cables and longer half shafts convert from steering to stationary the engine and trans mount with 3 solid mounts
any one know what kind of frameing would i need
Two words: Too much! Period. Better to find a low-end model Fiero, cut-up it's space-frame and fit it underneath.
Stuff like I've mentioned has been done alot by component car builders so that oughta give you a clue as to look for tips (Re: Kit Car Magazine & Kit Car Illustrated).
Go beyond the "bolt-on".
I was going to say what ^ he said. Better off starting with a Fiero.
^I've always wanted to get a 4cyl fiero and swap the Iron Duke for an eco...only question is, other than engine mounts, would the transmission bolt up?
_________________________
Yes it would, Rob. All GM engines that are commonly found in FWD apps use what's called the "Metric" bellhousing pattern. For the record, THM 200's (Not THM 200-4R's) & 700-R4's (Latter to become 4L60's & 4L60E's) were also made with this pattern to allow use of those engines in RWD apps (Camaros, Firebirds & S-trucks). The olny headache you'll face is that the Fiero auto trans' (If that's the way you're going) during the car's production was non-electronic in control (Re: Mechanical shift, TCC & line pressure control internally, with throttle-valve cable hook-up to throttle lever). The OBD-II might look for those extra inputs & outputs and wonder where they are and set a fault code if you don't use a coresponding production trans for the engine or turn off those functions with a HPTuner. Otherwise, it's just a matter of matching the clutch pieces up so they connect.
Someone brought a fiero to the bash with an ecotec in it. its possible
The Quad4 is DOHC, and it uses the same pattern. Same story with the LN2. If it's found in FWD apps, it uses the metric pattern. The General isn't one to change something that works just for one engine family like Mopar did (Don't get me started...).
Well, only one way to find out...
thanky for the sugestions guys
Nickelin Dimer wrote:The Quad4 is DOHC, and it uses the same pattern. Same story with the LN2. If it's found in FWD apps, it uses the metric pattern. The General isn't one to change something that works just for one engine family like Mopar did (Don't get me started...).
The LN2 uses the Isuzu tranny whereas the 2.4 is a Getrag (like the V6 fiero).
Quiklilcav wrote:The Quad 4 does NOT use the same pattern as the LN2. Although GM was good enough to use the same pattern on most V6's and I4 OHV engines, the DOHC's got a separate pattern. That's what I'm talking about. I am not terribly familiar with the Iron Duke, but I'm pretty sure it has the same pattern as the LN2, so to put in an Eco would require a different tranny.
Thanks. Another question though, what transmission does the new 3.6l use? I would love to swap one of those into a Fiero.
Rob Durrett wrote:Nickelin Dimer wrote:The Quad4 is DOHC, and it uses the same pattern. Same story with the LN2. If it's found in FWD apps, it uses the metric pattern. The General isn't one to change something that works just for one engine family like Mopar did (Don't get me started...).
96-99 5 speed LD9's use Isuzu transmissions. The type of transmission is meaningless. The bolt pattern on the transmission as well as the mounting points decide whether it will be a relatively easy swap or not. I too don't know if the Iron Duke has the same bolt pattern as the LN2/V6 engines but
LN2, Quad4/TC, ECOTEC, L-series (saturn motor) are all GM I-4 platforms that use different bolt patterns.
"Youth in Asia"...I don't see anything wrong with that.
LN2 was around in block design since the '82 model year, and all GM factory transverse mounting apps engines use the same bellhousing mount face with few exceptions (Northstar, Aurora). The LN2 isn't one of the exceptions. I recall seeing articles in Hot Rod & Street Rodder that pertaine to the Quad4 that said it does use the same bellhousing mount face design as other common factory transverse mounting application engines, but I'll need time to search for it as it's been a while since I've seen it. Think I'll check the Mitchell manual while I'm at it. Oh, and Rob... the 3.6L V-6 found in the new CTS uses on of the new 6L--E series transmissions, but I don't know what bellhousing design it uses. Like I said: Only one way to find out...
There are a multitude of people that have done Quad 4/TC swaps from LN2's in the past with Whitecavy probably being one of the last to do it. They DON'T have the same bellhousing bolt pattern.
Nickelin Dimer wrote:LN2 was around in block design since the '82 model year, and all GM factory transverse mounting apps engines use the same bellhousing mount face with few exceptions (Northstar, Aurora). The LN2 isn't one of the exceptions. I recall seeing articles in Hot Rod & Street Rodder that pertaine to the Quad4 that said it does use the same bellhousing mount face design as other common factory transverse mounting application engines, but I'll need time to search for it as it's been a while since I've seen it. Think I'll check the Mitchell manual while I'm at it. Oh, and Rob... the 3.6L V-6 found in the new CTS uses on of the new 6L--E series transmissions, but I don't know what bellhousing design it uses. Like I said: Only one way to find out...
Thanks. Well, if I ever get the money to, I'm doing it and then supercharging it!
Ecotec engines need an 'ecotec transmission'
In simple terms they are in there own little world.
If using the ecotec tranny isnt needed, you can use a spacer and adapter plate as I did.
I used the MT2 transmission which is similar to the MK7 used with LN2s, but the gearing is sweet for the ecotec or any high revving DOHC.
The 2.5L Iron Duke, 3.8s, SBC, 3400,LN2s ,etc.all share the same bolt pattern.
Ecotec into a fiero is straight forward, and is the only GM mid-engine that is cost-efficient to swap it in, most likely not a mid engine cavailer.
Heres a pic the day after i got it into the car.
now The L61 Powered Fiero
PURE DICE, PURE Design.Innovation.Creation.Excellence.
Not bad. Say, where are you locating the PCM? And how is the ALDL going in this swap, too?
Nickelin Dimer wrote:Not bad. Say, where are you locating the PCM? And how is the ALDL going in this swap, too?
I megasquirted and got rid of all that extra crap, no emissions, no BCM or PCM. That pic is way old its much different now anyways.
Quiklilcav is correct the SBC does not use the same pattern, adapter plates are required for swap my bad
Standard, Quik? I believe you mean Chevy in as Buick, Oldsmobile & Pontiac after '67 ('66?) used the same pattern amongst themselves upon their in-house divisional engines that was nothing like what Chevy used. Caddilac also made use of the B-O-P pattern on it's engines during their production. Don't ask me about AMC who also used THM trans', as I don't remember what they look like. I do know that the 200-4R has a special bellhousing all it's own, a universal design that matches both Chevy & BOP patterns but not Metric. Just throwing this out there for clarity...
I agree about it being much easier to start with a Fiero (I would like to see a turbo Quad...), but just for argument's sake, there was a mid-engine Acura Integra in Super Street's USCChallenge that used the drivetrain from a Prelude (H22+5-speed)...
I'd rather just do the Fiero myself, but a mid-engine cav would certainly be unique. It'll take a sh*tload of fab work though...
