1.6 Rocker Help!!!!! - Performance Forum
Friday, November 30, 2007 8:34 AM
I have a 96 sunfire w/ the 2.2L OHV. Is there a 1.6 rocker that will drop right into this motor. I want to use the guide plates.
Re: 1.6 Rocker Help!!!!!
Friday, November 30, 2007 9:00 AM
There is a thread on this somewhere... The part number for some good ones is 10759-16. Its for 16 crane gold roller rockers with a 1.6:1 ratio, and are not self-aligned, so you would need the guide plates. I dont know if they "drop in" but they fit and work. You might want new springs aswell, because they probably wont be able to handle the lift. 12499224 GMPP ls6 springs. You have to get the spring seats machined to fit them at the right height, but they work great, and can handle more lift then the 2.2 ohv can handle! Hope this helps.
Friday, November 30, 2007 9:08 AM
Oh, forgot to add, those part numbers are for sets of 16, you will only need 8. You can split them with someone else. I may be interested in them! Search for rocker in the performance forum. You'll be surprised how many hits you get. And most should help!
Edited 1 time(s). Last edited Friday, November 30, 2007 9:15 AM
