Ecotec engine swap - Performance Forum
Ecotec engine swap
Monday, August 21, 2006 11:37 PM
Not positive if this would be the right forum to post under but Ill give it a shot anyways.... I have a 96 cav with the original stock 2.2L factory engine... I wanna put some boost and nitrous into my car but want a new engine also.... I want to get an 03+ ecotec engine so they'll be better for taking the boost and nitrous... with this swap, what all will I be needing?? Engine, trans, wiring harness, ecu, ect., ect., ect.???????? Any help would be awsome.... Thanks
Re: Ecotec engine swap
Monday, August 21, 2006 11:48 PM
You will need absolutly everything..rad,axles,engine,tranny,all wirering through out whole car, gas tank, lines, sender all that
soooo basicaly if it comes off you need it
phil
Tuesday, August 22, 2006 4:56 AM
best bet is buying a -3 jbody that was rear ended and swap everything over
Tuesday, August 22, 2006 6:21 AM
Philly D wrote:You will need absolutly everything..rad,axles,engine,tranny,all wirering through out whole car, gas tank, lines, sender all that
phil
True. Getting a wrecked J with a ecotec is the best option.
Tuesday, August 22, 2006 9:15 AM
i have almost complete head for sale, email me
but you will need engine, trans, top motor mount, axles, wiring, ecm, gas tank and probably a lots of little thing
i'm actually working on getting parts right now for this, but i'm doing it with out the ecu, wiring, gas tank and a few other things.
