I got a 2.3 manafold and was wondering can you still use the 2.4 t/b or do i have to use the 2.3 and how do i mod the 2.4 if i can use it. Also what length bolts do i need when i get the adapter flang?
and mod your cable bracket to fit (redrill one hole) as well as tap another hole on your TB.
Sask GM Performance (formerly SaskJbody) president
mattf wrote:and mod your cable bracket to fit (redrill one hole) as well as tap another hole on your TB.
Huh?
I didn't have to do any of that... The cable bracket I had to notch out , but only because of the auto tranny. I didn't have to tap any other holes or redrill a hole in the cable bracket.
if you can find a 2.3L TB i would use it. Its 56mm over the 54mm of the 2.4L TB.
Click the banner to enter the best Quad4 & Twin Cam site on the internet.
May i make a suggestion? even though you can use the 2.4tb, a better choice would be the 2.3tb because its larger. 56mm as opposed to 52mm.
cool thanks guys that helps
And i think if your gonna go with 2.3 tb, u need a 2.3 tp sensor, map, and i think IAC.
Shifted wrote:mattf wrote:and mod your cable bracket to fit (redrill one hole) as well as tap another hole on your TB.
Huh?
I tapped the other hole so I could put a bolt into the TB to hold the braket on. This seemed better than using a nut/bolt for that hole. I tapped the other hole so the bolt that bolts the tb to the mani could fit in, iirc.
