anyone use these? - Performance Forum
anyone use these?
Saturday, February 11, 2006 3:32 PM
has anyone used these? HyperVoltage System MR-S on the maxximumboost.com website? just curious about if they are worth it. im looking to make everything as efficient as possible before going into the big mods
Re: anyone use these?
Saturday, February 11, 2006 3:35 PM
also i know i have another thread about engine grounding, but would this and the grounding be optimal?
Saturday, February 11, 2006 3:37 PM
I have not used the hypervoltage system, but all it is, is a voltage regulator, by the way, your alternator has one. So unless you are having problems with shorts or bad grounds, its not needed.
Save our Environment, Plant a bush back in texas.
Saturday, February 11, 2006 4:25 PM
El Fuego ( the unstable ) wrote:I have not used the hypervoltage system, but all it is, is a voltage regulator, by the way, your alternator has one. So unless you are having problems with shorts or bad grounds, its not needed.
exactly
You'll never touch God's hand
I've seen the ways of God
I'll take the devil any day
Hail Satan
