Okay, so I was going to pull the aluminum quad 4 cover off and start to pollish it tonight. I took out the bolts and began to pull the cover off when I got called into work. Went to put cover back on, and had a hard time getting the white sleeves seated properly back into the rubber boots. The car starts, and runs fine, but i don't know if the fact that the tabs aren't fully seated is going to be a big problem. i'm at work, it's snowing, and I only have a little daylight left. need help ASAP. Thanks.
Gotta keep on livin', L-I-V-I-N
I usually put the boot on the coil first and slide those over the sparkplugs.
Not really sure if you should drive it home.
I would ... but thats just me.
Save a Tranny, Roll-on
15.3@88m.p.h.(I/E)
15.2@94m.p.h.(S/C'd)
15.5@89m.p.h.(Stock GTP)
It seems to be running fine, I drove it to go get some food since I'll be here for a while. what is the worst that can happen?
It will missfire and shake like crazy and then leave you stranded somewhere. Just go an put it on right. What is so hard about that?
It was snowing and dark in the parking lot last nite. They must be seated properly though because the car isn't shaking, and I made it home. Nothing hard about it, but thanks for your advice.
Bob
