I got a hose fitting for the hole in the manifold just after the front runner. I have a plug in it now but im thinking I will run the oil/air separater hose to the fitting there. Would running it there cause any problems since it would see vaccuum? Or should it be fine to run it there? Or should i just run it into my intake tube and let that be?
Thanks in advance...
i pluged mine...i found noticably better performance from it...not to mention the intake will whistle better if its plugged
...run your oil/air hose to the cai
i have a breather filter installed now but im tired of the oil that comes out all over the place, and the smell when sitting in traffic.
Actually thats what that big plug is back there for anyway.
The oil vapor return likne or whatevr.
But I used to use a breather filter, but dont now.
I just have the original factory stubby hose on there hanging out.
No excessive oil splashing anywhere or nothing.
If you're getting that, there maybe a different problem going on.
-M
if you just put a breather on that box oil will cover your engine...at least it has for alot of people..run a hose from there to your cai pipe
