how do you get the Serpentine Belt on a 96 sunfire - Performance Forum
Sunday, September 18, 2005 6:28 PM
Hi Guys
I need to know how to get the Serpentine Belt on a 96 sunfire and is there a special way to get the serpentine belt on bc i cant get it on the alteratare at all and its the correct belt.
Go Check Out My Z26 Message Board @ http://v6z26.proboards12.com/index.cgi and tell me what you think Thanks
Re: how do you get the Serpentine Belt on a 96 sun
Sunday, September 18, 2005 7:01 PM
which engine?
Sunday, September 18, 2005 7:03 PM
2.2 ohv
Sunday, September 18, 2005 7:19 PM
the grey piece in the back(look for the hole) uses your socket wrench square head to rotate it, run the belt all around and then use the wrench to slip it on a wheel, its much easier to put it on a pulley other than the alternator most of the time.
Sunday, September 18, 2005 7:25 PM
this is a 1996 motor
Sunday, September 18, 2005 8:31 PM
~bump~
Monday, September 19, 2005 7:46 AM
Seriously man, considering how many of these little questions you ask, and how impatient you are (i.e. bump, bump, bump), you NEED to go out and spend the $15 for a Chilton's or Hayne's manual for your car. All this stuff, plus a lot more, is right in there.
As for the topic, have you tried loosening the tensioner? 15 or 17mm wrench I think. It's the pulley in the very middle.
<img src=http://hometown.aol.com/yogiandbooboo7/images/french.jpg>
Monday, September 19, 2005 11:56 AM
I have a hayne repair book and it doesnt tell me how to do it so I really need help on doing it bc this is my second day of trying to get that belt on and plus i had my dad try to put it on last night and he cant even do it what is the easy way to get that belt on because I need to know RIGHT NOW
Monday, September 19, 2005 12:21 PM
come on please somebody help me
Monday, September 19, 2005 12:25 PM
The tensioner, do u know which one that is, if you put a wrench on it (closed or open, doesn't matter, closed might bea easier. ) put it on the bolt that holds that pulley on the tension, and rotate it clockwise, i think, and it will seem to release tension. while it is rotated, have someone pull the belt onto the alternator pulley. Run it on everything else first. Then do the alternator pulley as i said above. I've done it many times before. Its easiest if u have two people, because rotating that wrench, its in a tight spot. and putting the belt on is best done with two hands. to get it over the alternator pulley.
Good luck,
Monday, September 19, 2005 3:57 PM
can it be the tenisoner not releasing itself or not because I think its still locked or something because all i can do is pull it down or unbolt the pulley off.
Monday, September 19, 2005 5:03 PM
Tuesday, September 20, 2005 7:11 AM
Xtreme96Sunfire wrote:can it be the tenisoner not releasing itself or not because I think its still locked or something because all i can do is pull it down or unbolt the pulley off.
I KNOW this was covered in my Chilton's manual, so I don't see why it wouldn't be in a Haynes...
Anyway, when you 'pull it down', you are effectively shortening the path the belt has to cover, and therefore you have extra slack. When the pulley is 'down' put the belt on (and keep the pulley 'down' until you're down).
