thought i'd post this in here since not very many people resopnd in the other one too quickly. im hving my oil pan gasket looked at again because it was worked on n it leaks more now with a new one then the old busted one. so my question is if i change it i have to remove the lower ngine mount, in doing so will the motor stay in place like it is or not without the lower mount in place? also if i haveta do it i want to put something around the the outside of the pan where the gasket goes to make sure it dont leak anymore so what is some sealer stuff i could get to do this?
2.340 - 60,
16.591 @ 80.52 - 1/4
Guesswho69000@hotmail.com
Have you ever read a service manual or even a Haynes/Chiltons? They give you step by step directions for things like this.
Its much easier than you're making it out to be, and if you had someone else do a new gasket for you, why wouldn't you take it back since they didn't fix it?
ok so if i take out the bottom engine mount will the engine stay put n not fall on top of me? and no ive never read the Haynes/Chiltons manuals. what are they?
2.340 - 60,
the gasket is like a silicon matterial and a metal ring. as long as the top mount is on its not gonna go anywhere.
