Throttle Body HELP - Performance Forum
Throttle Body HELP
Thursday, August 25, 2005 9:04 PM
Ok, can someone give me a link to a good throttle body, I cant seem to find any for a 2.2L '05 ECOTEC anywhere. And I really want one, so if someone could help out I would appreciate it. -thanks
Re: Throttle Body HELP
Thursday, August 25, 2005 9:11 PM
I personally have the RSM Racing 62 MM Throttle Body. If you want more info on it, check out RSM's catalog:
RSM Racing's Catalog for the ECOTEC
Thursday, August 25, 2005 9:46 PM
^^^NJHK beat me to it. would've gave him the same link. rsm makes some good parts from what i hear
People say that what doesn't kill you in this life
will make you stronger. I'm not sure if that is true
or not, but i do know one thing-You have to learn from
it and it has to make you better.......it has to.......
Friday, August 26, 2005 2:19 AM
do your exhaust before buying a TB. the gain will be higher and it will perform better. You don't need the tb unless the engine can take more air. You try to bring more air in and you can't push more out so the result and close to none.
Gilles
2.3 Ho
Friday, August 26, 2005 2:35 AM
Mfk-223 wrote:do your exhaust before buying a TB. the gain will be higher and it will perform better. You don't need the tb unless the engine can take more air. You try to bring more air in and you can't push more out so the result and close to none.
Agreed
Friday, August 26, 2005 4:09 AM
yup, just more noise, and loss of low end most times.
