Hey i have a 99 2200. I was hoping for some input on this to see if I'm on the right track. I'm wanting a Pacesetter 4-2-1 and a Magnaflow high flow cat. Ive read "some fabrication may be needed" for some header types. Will this Pacesetter be ok to just bolt on (no O2 relocation, flange problems, etc) and will the Magnaflow be able to be welded into 2 1/4" exhaust with no problem and also not jack up the obd2? Any other issues that I'm not thinking of, or any suggestions? Any input is appreciated a lot, thanks.
I root for the underdog...figured I might as well be one
The Pacesetter should hook right up with no fabrications. Yes, the Magnaflow cat will weld right up as long as you get a 2 1/4". Mind you, if your going to do this, you might as well replace the whole system otherwise you won't gain as much power as you should. Your exhaust system is only as big as the smallest point.
Yeah im gonna have 2 1/4" made. Thanks again for your help on my posts.
