exhaust problem - Performance Forum
exhaust problem
Friday, May 06, 2005 11:18 AM
ok I have the pacesetter header, high flow cat, 2.5" catback exhaust on my 1998 2.4L. I drove it for 2 days and the check engine light comes on, I took it to a shop and they told me I needed a new O2 sensor that goes in the header. So I replaced it with a Bosch O2 sensor and had the code cleared. I drove it for about 2 days and the CEL comes back on, so I have the shop see what was wrong and the scan tool said "bank 1 sensor2"the same as before with the factory O2 sensor. Does anyone know what the problem might be? Thanks for any help that you can give me.
Re: exhaust problem
Friday, May 06, 2005 11:44 AM
Second o2 sensor. Did you remember to put it back in.
My cardomain
Re: exhaust problem
Friday, May 06, 2005 11:48 AM
Everything is hooked up and installed. I haven't replaced the 2nd,after the cat, O2 sensor yet because I think that it is reading to much flow. If I get a code for the 2nd one I will just get a simulator for it. I was told that "bank 1 sensor 2" is for the first one, is that correct or is that the code fo rmy 2nd O2?
Re: exhaust problem
Friday, May 06, 2005 11:54 AM
You only have one bank of cylinders. So sensor two would be the sensor after sensor one. So Sensor 2 is the o2 sensor after the cat. All that sensor does is monitor the efficiency of the catalytic convertor.
My cardomain
Re: exhaust problem
Friday, May 06, 2005 12:09 PM
I just called the shop and asked him which code it was and then he told me that is was throwing a heater circuit code, or something like that. So the guy made a mistake and all I need to do is either replace the after cat O2 sensor or get a simulator. Thanks for your help on this Sunfires rule! (Tom) I really appreciate it. Now I can go a drive my car YEAH.
