I cant find anything usefull with search button so here it goes. What would I need to do to make a 99 head work with a 97 block? Are they the same except for the egr valve?
You will need to get an egr block off plate and gasket as well as an egr simulator or you will have a permanent cel.
<br><img src="http://memimage.cardomain.net/member_images/8/web/728000-728999/728095_1.jpg">
Yes officer I knew the speed limit was 50
this swap would also include the 2200 intake manifold as well, correct? if not, you might want to look into that, considering your have many options for topfeed injectors in the 2200 ln4 as opposed to the 17 lb/hr sidefeeds in the 2.2 ln2
KC Absolute Performance wrote:this swap would also include the 2200 intake manifold as well, correct? if not, you might want to look into that, considering your have many options for topfeed injectors in the 2200 ln4 as opposed to the 17 lb/hr sidefeeds in the 2.2 ln2
maybe i read that worng or something but Melaza has a 2.4, not a 2200
if you can live w/ the light, all you need (to my knowledge) is a 99+ exhaust manifold gasket..i'm pretty sure everything else is the same.
99CavyZ ~ Black ~ 5-Speed
"If It Bleeds For A Week Straight, How Come It Doesn't Die!?"
99 exhaust manifold gasket, and an EGR simulator if having a check engine light causes your car to pass inspection in your state.
-da chinchilla
<img src="http://registry.gmenthusiast.com/images/jiggamon/avatar15569_2.gif">
hey ive got a 2200 2001 sunfire and im looking to find out what kind of port and polish to get ? or is there a better head that will mount up?
ITS ALL FUN IN GAMES TILL SOMEONE GETS SHOT IN THE LEG
o come on someone has to know something about this (event you still out there) ? ive gotta get my car down to low 14's before next month. got a big race comin up . im already at 14.7 just need to drop a few more pounds and grab a little more power . also will the upper motor mounts for the 2.4L work on a 2.2L ? im talking about the ones from RKSPORT.COM? ive got the lower but no upper and it still just isnt stiff enough.
Yeah, I have the 2.4. Here in Ohio I wont pass the E-check if I have the light on. Not that my car is 100% legal, but I still need to pass emissions some how. Is it true that the simulator makes our cars hesitate during acceleration.
