hey guys. ive got this wierd thing going on with my driver side blinkers. The passanger side ones are working fine, but both front and rear driver side ones are messed up. inside the car my left ticker is going twice as fast as its soposed to, and the front blinker flashes at the same pace twice as fast. but then the rear is just staying on, not flashing at all just a solid light. i don't know whats going on can anybody help?
Swap the driver and passenger rear bulbs. If the problem follows, its the bulb. If not, its probably the socket.
ok i can try that. oh and on a side note are you using two different acounts to post.
Did you check your blinker fluid?
Naw, it just sounds like your bulb is burnt out in the rear. Try what Kardain suggested, and see if that works out for ya.
Nope. I have different sigs for different forums.
Yep just replace the bulb, it should fix it
2002 Chevrolet Silverado 1500 Z71
yeah i picked up a couple of bulbs from shucks. so its all fixed now.
