Gas tank heat shield removal - Maintenance and Repair Forum
Thursday, October 06, 2005 8:45 PM
Not sure if this in the right forum or not, but here goes. I need to replace a fuel pump on a 01 2.2l cavalier. I have done this on earlier models, the newer ones have a heat shield that needs to be removed before the tank can drop. It appears to be riveted in. Can I drill these out, or am I risking a spark too near the tank? Is there another way to do this that I am just not seeing. I appreciate your help.
Rick
Sig'less since '02!
Re: Gas tank heat shield removal
Friday, October 07, 2005 12:39 AM
Drop the two straps, and slide it down and out to the passenger side of the car. No need to remove the heat shield or exhaust.
Friday, October 07, 2005 9:39 PM
I used an angle grinder to get one of the strap bolts off and no fire. I think you can drill into the shield with no problem.. but I'm pretty sure you can just slide the tank out to the passenger side.
Sunday, October 09, 2005 8:34 AM
thanks alot guys. had to take it to a guy with a lift and we used Lenko's method. If I didn't have the lift I would probably drill out the bolts though.
Rick
Sig'less since '02!
