Rough idle and lil bit of black smoke?? - Maintenance and Repair Forum
Thursday, June 09, 2005 5:17 PM
I just got my car back from the body shop and now have a rough idle motor shakes and have a lil bit of black smoke while its running. On start up it puffs more black smoke.
98 Z24 2.4L
What could cause this?
thanx
Jon
Re: Rough idle and lil bit of black smoke??
Thursday, June 09, 2005 10:03 PM
i've had the same thing, rough idle, black smoke pours out when i take off, i bought some octane booster, the kind that's in a 4 pack it also has Dale Jr's outslaw insignia on the side, autozone has it, but so far it's cleared up the roguh idle, and there's a very little carbon on my exhaust pipe, so try that out. It may not be a complete fix but it sure will help clear out the foulness.
Thursday, June 09, 2005 10:13 PM
The black smoke means the motor is running rich.
The causes for this are extensive on a computer controlled car, but you should have a code somewhere to better point you to the cause of it.
Thursday, June 09, 2005 10:45 PM
I'm going to go out on a limb and assume it's possible that the smoke is blue. If so, you may be in need of piston rings.
Zac
Friday, June 10, 2005 6:18 AM
I hope its nothing major i baby that damn car like no other.
Today i went and got new plug Bosch platinum 4 and the front 02 sensor.
How hard is the sensor to install?
And also is there anyway i can get codes read to direct me in the right direction?
thanx
jon
