does my 98 2.2 have a pcv valve? - Maintenance and Repair Forum
Sunday, May 15, 2005 6:36 PM
like the topic says? i did a tune up and bought the pcv vavle yet couldnt find it.
Re: does my 98 2.2 have a pcv valve?
Sunday, May 15, 2005 6:42 PM
If you're looking at the engine from the front of the car it should be on the left hand side at the back of the valve cover. There is a nut you have turn loose and then pull the hose off - you need a pair of needle nose pliers to get the valve out. Just put the new one in the same way as the old one.
Sunday, May 15, 2005 10:52 PM
the 2200s do not have a removeable pcv valve. the 2.2s did come with one.
Monday, April 16, 2007 9:51 AM
How is the PCV removed on the 2.2? I have found where it is, but cannot get it out?!?
Monday, April 16, 2007 10:07 AM
the outer part, looks like a star, is just a retainer. you use a pair of pliers on it. it twists out, then you pull out the old pcv, drop in the new one, and put the star back on tighten it down and drive away.
Tuesday, April 17, 2007 1:38 PM
Thanks, I'll have another look at it.
