Car shakes a bit at idle - Maintenance and Repair Forum
Thursday, May 12, 2005 5:00 PM
Hey guys...I just finished a good sized tune up on my car(air filter, spark plugs,oil change cleaned the throttle body...changed the muffler) ....Ive had the car a week (96 Auto Z-24) it idles at 700-750 when it warms up ...first ..is this normal ....second if you sit in the car it shakes a little bit as if its struggling ....very slight movement....if you listen to the exhaust (its a magnaflow) it makes like its idling a bit off..in reality the idle isnčt really moving...so What could my minor shakes be....Im thinking egr or iac....By the way when driving everything is fine(acceleration, gear changing etc...)
Re: Car shakes a bit at idle
Thursday, May 12, 2005 6:35 PM
Lots of thing can cause a rough idle, EGR, IAC like you said, also a vacuum leak. However if you have a vacuum leam you would most likely get a code for the engine running to lean, and STFT would be above 2% but you would need a code reader to see that.
Thursday, May 12, 2005 7:01 PM
Monday she goes in to the shop to get a diagnostic done....well just have to see
Thursday, May 12, 2005 8:54 PM
SEA FOAM!!!!!!!!
