Can you go bang top down on the IDI cover using the side of your fist pretty hard and tell me if there is a rattle from the timing chain area?
Lol just curious before I remove the timing cover and take a peek. I think I might have something that failed in there because my car has excess vibration and that's the only area I can tell so far that makes noise with all my banging around examining potential sources of vibration/noise. The chain/guides/tensioner are from 2008 so they've been through a lot, and I've wheel hopped pretty intensely recently and shift hard, so who knows.
2001 Olds Alero (LD9)
650 whp / 543 ft-lb
@turboalero
If it's auto have someone hold the brake and put it in park, reverse, drive while you watch how much the engine rocks in the bay. It's probably just a bad mount.
"In Oldskool we trust"
I'm not new to this platform, lol. It's definitely not any of the engine/trans mounts.
It's a manual, hence why I mentioned the wheel hop and hard shifting as a potential cause to whatever is wrong. It's definitely an internal rattle of some sort, just wondering if it's something new I'm noticing or if they all do that. So anyone with a 2.4L, please hit your engine and let me know how it sounds.
650 whp / 543 ft-lb
@turboalero
Didn't even look at the user name. My apologies, good sir
Damn I tapped things with a rubber mallet and it went away and now I can't make it make the rattle again lol.
When I rotate the crank by hand back and forth I don't hear anything weird from the chain area. Who knows, maybe everything is fine and my vibrations lie elsewhere. I haven't driven it since I tried dampening a few things in the bay that were touching hard objects.
650 whp / 543 ft-lb
@turboalero
Highly likely it's the timing chain tensioner. These are good for about 80k miles. Anything over this is a gift. Also could be the water pump. Best to replace both when in there.
Have a listen, I got video just before it quit making the noise lol.
I pinpointed my vibration issue though, it's the horribly warped v-band on my downpipe as I originally suspected. Easy fix.
Still, curious what this was. Can't reproduce it anymore, just was a random observation that one time.
650 whp / 543 ft-lb
@turboalero
