Multiple lights on. But no DTC's - Maintenance and Repair Forum
Wednesday, January 23, 2013 9:17 AM
Just got a repaired prior salvage 04 cavalier LS Sport 4 Dr the other day. Runs and drives great but has some lights on.
I hooked up my OTC 3108 code reader and pulled 3 codes off of it.
PO 130 (HO2S Circuit Sensor 1)
PO 340 (CMP Sensor Circuit Low Input)
PO 442 (Evaporative Emission (EVAP) System Small Leak Detected)
So today I went and pulled the coil pack/ICM assembly and evap solenoid off of my wrecked 05 Cavalier LS 2 Dr. I decided to wait and fix the oxygen sensor for a later date. Cleared all codes with the OTC 3108. Started and shut off car about 3-4 times. Service light, ABS light and Track Off lights still on. Hooked up code reader again and car shows no codes stored. So I went back home from where car is located (bout 7 miles give or take a couple). Hooked up code reader again and still no codes. But all 3 lights still on. Is there other codes that my code reader cannot read? Or could the instrument panel be malfunctioning?
Any help would be greatly appreciated.
Re: Multiple lights on. But no DTC's
Wednesday, January 23, 2013 10:02 AM
Is this a actual scanner or a quick little code reader? sound to me like you have a abs code stored and you dont have a actual scan tool to read it. most likely a torn abs harness or bad front wheel speed sensor
Wednesday, January 23, 2013 10:37 AM
It's just a code reader.
This one here... OTC 3108
Will have to check the speed sensors out after bit.
Wednesday, January 23, 2013 10:42 AM
Does the computer use the wheel speed sensors to control the speedometer as well? Or is there another speed sensor in transmission for that?
Thursday, January 24, 2013 12:13 PM
Nope that wont read ABS Codes. speedo uses speed sensor on transmission
