Ive seached and looked around, but the Topics seem to be dead. I got a 97 cav, 4psd auto. the vss sends signal, my scanner reads it. But the odo and speedo are dead. Besides a typical GM wire issue, Could the Cluster be bad? has anyone encountered this scenario?
Fireboy153
Brady Fire Co. - Station 150
Long Live The Sunflower! (yea its not so "cool")
That happened to me. And I turned up a lot of heat on the stepper motors in the cluster go bad and stop driving the needles. I took the cluster apart, and re-soldered in new motors... working 100% now, but come to think I'm not sure if the 97's used the same cluster as the 02-03's.
Edited 1 time(s). Last edited Monday, September 17, 2012 3:37 PM
![](http://img13.imageshack.us/img13/7089/82491922.jpg)
I roll on steelies. Work-in-progress daily-sleeper potential.
http://www.j-body.org/classifieds/engine/60493/
Since both the speedometer and the odometer have stopped, I'd guess on a wiring issue. There is a single wire that comes from the ECU to the C100 connector at the firewall. I believe it's a green wire, that sends the VSS signal to the inside of the car. I'd almost guess there's a problem there somewhere. If only the speedo or the odo stopped without the other, then i'd guess one of the motors.
ive checked the wires and the motors, no luck. going to try a new cluster. poss. the issue. as you can see by the delay, this lay is in no hurry haha
Fireboy153
