Im getting an emissions code because of my iat...i repleced the motor and accidently ripped the wores out of the sensor..i purchased a new sensor and new harnes or my 03 but i cant seem to find where the wires go..i assume they r in the loom that the injector wires run thru...any help????
What exactly do you need to know? How the wires go into the connector?
i need to know where the wires go to. not the end that is attatched to the sensor, i know that end just plugs in, i got a new plug for it because i accidently ripped the wires out of the plug, and now i need to splice the wires into wherever they go...i just dont know where the other end of the wires are, i assum they are ran in the wire loom with the injectors and then they come out and go to the iat sensor on the intake. i basically need someone to follow the wire off the sensor and tell me where those wires go to
The IAT wires (tan and gray I think?) come out of the loom where the TPS and IAC connectors come out of...driver side of the intake manifold. Look where the harness splits below the battery tray, and starts to head across the front of the motor...before you get the connectors for the CKP, Knock, etc, there should be a branch that goes up to the manifold (in the area of the oil filter housing). I can't remember (as my harness has the IAT moved for the supercharger), but the IAT may come out of the loom a few inches before the IAC and TPS, or all three may come out together.
The injector harness only has the MAP sensor run through it.
thanks i hope this helps me.. got to wait till morning light now... i got to get it to pass inspection before i fight my inspection sticker ticket...its an 03.. only had 3 stickers on it ..oops
Let me know if you need any more info..I could take pics of my harness tomorrow since it's conveniently laying across my basement floor, lol
Excellent...thanks for the help guys i did find the wires...i did notice that in the intake tube and in the intake that goes onto the throttlebody...there is quite a bit of oil in there....tell me i still got some life in this baby
