Loaping engine idle problem - Maintenance and Repair Forum
Friday, July 30, 2010 6:29 AM
Recently my car started acting kinda funny and at first I thought it was the fuel filter because it acting like it wanted to bog when you gave it gas and I know it couldn't be the fuel pump bc it's almost a brand new racetronix fuel pump so I changed out the fuel filter and the old one was pretty dirty so I thought I nipped it in the bud ehhhh wrong took it for a drive around the block and got on it and after about 10-15min it started boggin again!! And when at a stop the car would idle really funny it was loaping like I had a 1000hp stock car or something ha. So I figures maybe idle sensor or something of that nature I did a little researce but no one having the same problem with a 04 cavi 2.2l ecotec. Any other ideas on what it could be thnx
Re: Loaping engine idle problem
Friday, July 30, 2010 9:38 AM
Update I ran the OBD scanner and it's throwing 2 codes one in particular I'm going to check out P0131 code - fuel system running lean. Engine vacuum leak or misfire. Or low fuel pressure- FUEL PUMP DEFECTIVE!!!
Friday, July 30, 2010 2:23 PM
So what now?
