It seems like I am getting a new random issue, after staring the car up it will randomly throw the ABS light, TRAC OFF light, and the Service Soon light all at the same time. I also get a stutter at low RPM's when I go to move, If I shut the car off and restart it the issue goes away. Any thoughts to lead me in the right direction?
Hey when i switched my new motor in my cavy, i had the same prob. Exjact same. There is 2 grounds going 2 a tranmission bolt. You can look right on the top of it. Theres 2 big grounds. There are not on the tranny to motor bolts but on the tranmission itself. Check those. I bet they arent tight.. Get back to me.
Have to check that out and see.
Thanks!
bump....what the hel was the problem
To be honest I haven't looked at that yet, though I did unplug each ABS sensor, clean the contacts and reconnect and haven't had any issues as of yet.
also just try the battery. sounds dumb, but it's worth a five minute test. after the car is started and run the alternator may charg it enough to not throw a light when you restart. just my .02
thats right. i said check the @!#$ battery. deal
loose wheel speed sensor wire, guaranteed. same thing happened one mine on of the wires, it pulled right out when i gave it a tug
