got an issue with the gas mileage - Maintenance and Repair Forum
Thursday, June 19, 2008 10:07 PM
ok seem like less then 3 years ago i could get about 350 miles a tank outta a full tank of gas(roughly 55,000 miles on the car)
Driving habits havent change any
maitenance has been on time or very close to
had changed out the spark boots to iraduim type rk sport sells at 35,000 miles(since ecotecs don't have plug wires only the intermediate conection)
tires have been kept up with so air presure has been good
and i travel around with about the same weight of items aside from about 60 lbs of turn out gear
since about 18 month ago im now down to 280 miles a tank
i've changed the plugs at 88,000 miles and tonight put the old factory spark boots back into the engine taking out the iradium ones that had been in tonight
Oil change is coming within weeks
new fuel filter is coming with it
have an intake on the car but it's been in the whole time even before i lost mpg(could get 25mpg with it in)
any other ideas as far as mechanical reasons why my mpg is down
i do all city miles(91,000 miles as of today)
Re: got an issue with the gas mileage
Thursday, June 19, 2008 10:17 PM
Carbon deposits, normal wear and tear on all moving engine components, cam lobes, timing chain (valve timing MAY have changed). Piston rings and cylinder walls wear, compression may drop slighlty.
Friday, June 20, 2008 12:21 AM
How many gallons per tank? Do not trust your fuel gauge to know when you are "empty". Has your fuel in your local area changed to E10 in the past year or two?
Friday, June 20, 2008 3:29 AM
Check your plugs. If they're black check your IAT sensor.
Friday, June 20, 2008 12:14 PM
yeah far as i know when they droped the mtbe they went 90% gas 10% ethonal , plugs had a litte bit of carbon on them when i changed to the news, the ait is ok is there anything specific that im wanting to look at , im planing to run some seafoam once i get paid to deal with the carbon
