I killed it!!! help!!! - Maintenance and Repair Forum
Monday, March 31, 2008 4:36 PM
I didnt have a lift to use when my clutch went out (I'll never let my girlfriend drive my car again), so I lifted the engine out to replace it... not quite sure what happened but when i buttoned it all up my number two cylinder kept filling up with so much gas that the cylinder goes dead. I've replaced the injectors and the computer but no results... So now im just looking for a whole engine to swap it with.
If you have any ideas in open to hear em.
Thanks
Andrew
Re: I killed it!!! help!!!
Monday, March 31, 2008 4:38 PM
Forgot to add....
I have a OBD2 reader but it gets NO signal from the engine.
Tuesday, April 01, 2008 9:46 AM
you should add your car to your profile, that way you don't need to list your motor or year etc. if you aren't getting any signal from your ecu via the obd2 then you don't have it hooked up correctly (or something needs fixing or replacing)...go through and check your harness and all the connections to make sure they are all ok. also check all the fuses if you haven't already.
Fallen I Am, Cursed And Destined To Burn -Dimmu Borgir
