engine knocking - Maintenance and Repair Forum
engine knocking
Wednesday, September 19, 2007 6:24 PM
i have an 02 sunfire with 130k on it but i had the engine replaced at 67k. so the new engine has about 63k. i was driving home from work and i pulled into my apartments i heard a knock, almost like a rod knock. no ses engine light is on but it is quite noisey at about 2k rpms. i was told maybe it could be a flat cam lobe. does anbody have any suggestions as to what it could be?
Re: engine knocking
Wednesday, September 19, 2007 9:32 PM
Whatever happened to Engine #1 ? ....
Could it be, Engine #2 suffered the very same ? ....
At least give us some kind of clue .....
Re: engine knocking
Wednesday, September 19, 2007 9:45 PM
ever bother to check the oil?
LE61T PTE6262 Powered
Re: engine knocking
Thursday, September 20, 2007 3:40 AM
^^^ what I was thinking.
Nothing sounds quite like a rod knock.
If it sounds like a rod knock.. chances are its a rod knock.
Flat cam lobe? WTF dont listen to that guy.
post a vid..... if it's a rod knock..... at least 70% or so of us on this site will recognize the sound emediatly.
Re: engine knocking
Thursday, September 20, 2007 11:34 AM
Do yourself a favor and check your spark plugs. Had "rod knock" on our boosted dually and it just ended up being a fouled out plug or two.
Re: engine knocking
Thursday, September 20, 2007 12:13 PM
i first engine i blew up with a 75 shot of nos in the 1/4 mile, i ran a 14.3 that was sweet. then i got the engine replaced under warranty. i pulled the valve cover off this morning and checked the cams, all look great. i am pulling the oil pan tonight or tomorrow. will let u guys know what i find but i think it is a rod bearing.
Re: engine knocking
Friday, September 21, 2007 7:53 PM
well today i drained the oil and it was dirty, then it turned silver. i pulled the oil pan and found some small metal shavings it. i am pulling the connecting rod caps off in the morning, hopefully the crank isn't scored. i hope i can just get away with replacing the connecting rod bearings.
