putting a 97 engine in a 96 car, Have some ??? - Maintenance and Repair Forum
Saturday, August 18, 2007 9:46 AM
Ok so Im pulling this 97 z24 motor and putting it in my 96 sunfire, it already came with a 2.4 5speed. my qeustion is will all the clips, plugs, and ecu from my 96 motor go with the 97 motor?? I know to put a 97 ecu in a 96 car you have repin it, but Im wanting to just run everything I have in the engine bay now.
Thanks
View my MySpace
Re: putting a 97 engine in a 96 car, Have some ???
Sunday, August 19, 2007 8:00 AM
anyone??
Bump
View my MySpace
Sunday, August 19, 2007 5:01 PM
Why not just run the 97 motor off your 96 PCM? They both should be OBD-II and have the same sensors and controls.
Sunday, August 19, 2007 5:11 PM
I did this exact swap in March. The oil level sensor does not mount up on the 97 oil pan. I have a loose connector that I couldn't find a match for near the fan, but no check engine light. If you want the oil sensor to work you have to swap the oil pans. I didn't realize this till afterwards and now i live with a check oil light on. All the other sensors hooked right up. Hope this helps
Monday, August 20, 2007 9:17 AM
thanks alot, I have the 96 motor still so I can take that oil pan and swap them out
Thanks
View my MySpace
