Car pulls left, auto tras mount? - Maintenance and Repair Forum
Under acceleration car pulls left, allready checked the aligment, balancing and rotated the tires a friend suggests the auto trans mount, can someone give me a light on this?
If it was a transmission mount you would likely notice more vibrations and possibly clunking from the transmission being able to move more than normal, power loss from drivetrain movement may also be noticed. It could also be torque steer if it happens under heavier acceleration. From the details you provided above i assume that it only happens during acceleration if this is not the case one or more of the brake pads or shoes may be dragging causing the car to pull to one side.
Oh yeah. Have someone watch the engine as you put the car in gear, and gie it a touch of gas. Have the parking brake WELL on, and ask if the engine looks to move greatly. Other simple check is to put a wheel in the air and turn it by hand. Different resistance will hint of a 'rolling' induced drift.
Did that test and engine is moving somehow, since I got the upper insert and dog bone in polyurethane which is stiffer I believe the trans mount gave up (itīs 10 years old most probably), so it is being replaced right now, Iet you know after I inspect the old mount.Thanks.
The old mount was not broken although the rubber was kind of soft, anyway got the new mount and car still pulls left most noticeable when launching, could it be the hub? or CV axle? I remember hitting a sidewalk in a curve about a month ago.
I think you need, A wheel alignment done, That should correct youre pulling.
Good Luck.
Mine pulls left too on acceleration, I always thought it was just torque steer from the unequal length axle-shafts, maybe I need to be looking at my tranny mounts, since I already have the RKsport engine mounts.
Luis Baptista wrote:Under acceleration car pulls left, allready checked the aligment, balancing and rotated the tires a friend suggests the auto trans mount, can someone give me a light on this?
Alignment is ok double checked. I will keep looking, maybe a wheel bearing.
if it was a wheel bearing you would hear a humming noise coming from your tires. if your cv joint was bad, you would get a clunk sound. check your outter tie rods and see what they look like.
Just throwing something random out...but maybe a bad ball joint? Or maybe something is just loose?
Loose tierod end? that sometimes is the problem on some gm cars.
http://
ding ding ding
mine pulled left after getting my sub frame replaced a few years ago, I found that the shop never tightened the a-arm bolts on either side and the a-arms were just bouncing around. Coincidently, it was after hitting a curb sideways at 40mph
Scott
When I boost, you boost, we boost
You have been banned from NEJBODY.
You've displayed wayyy too many acts of pushing people to their limits.
It's never cool to tear people down for what they want to do.
NEJBODY is a team. We're not the same as JBO where everyone bashes on eachother.
I'm surprised you show up to our meets after half of the things you say on here.
Sounds like a bad radial tire. Rotote the tires and see if the pull moves.
ASE Certified Techician
DaimlerChrysler Certified Techician
Va Safety Inspector
Member Option D Racing
I will rotate the tires, front left is going to the back left and will see, Thanks very much.
JCBLL95 wrote:Quote:
ding ding ding
ding ding ding in an auto the axles r the same length in my 2.4L
lol duno bout u guys or wut u have
i see thread starter has a Z24 so its nothing to do with axle.. both r exactly the same
if u hit a curb check your strut and ur knuckle.. u could also messed up inner or outer tie rod depending how bad u hit
Nothing seems to be loose or bent I rotated the tires and still pulls left more when going uphill, I was told to change the front tires from its rims and try (right rim to left tire and viceversa) , so Iīll do that next.
ya i was gonna say that switch the sides.. if its not that who knows
I had the front tires turned in their rims and problem solved.
