highbeam harness - Maintenance and Repair Forum
highbeam harness
Monday, May 07, 2007 4:17 AM
hey, I have no highbeams and my day time running lights are also screwed up. working sometimes and sometimes not. anyways i just tryed a new swtich and didn't help. So i guess i have to take out the harness and check it over. What way is the easiest for this, and what colour is the highbeam wire, also will I have to check any other colour. Thanks alot
jeff
Re: highbeam harness
Monday, May 07, 2007 10:29 AM
Check the DRL relay. This seems to be a semi-common problem. When you say the DRLs are screwed up, can you be more specific? Does one side work but not the other? Do neither work?
Monday, May 07, 2007 11:49 AM
hey, when drl go out, they both do. They start to blink fast, and then then quit, when this happeneds the yellow light in my dash also blinks and shut off. my Highbeams never work at all, but i have no problems with my low beams, is the drl relay the black box inside my fuse panel, the one in the car, thanks alot
Monday, May 07, 2007 11:34 PM
Yes, its the lil black square in your fuse panel on the left end of the dash. And since your car is a 2k with single bulbs, I'm gonna GUESS that the wires for the highbeams are slightly thicker gauge than the lows, since highbeams uses a higher wattage filament in the bulb.
