Changing Head Light bulbs Z24 2001 - Maintenance and Repair Forum
Friday, April 06, 2007 5:23 AM
bluedriftcavy(a.k.a. wayne) wrote:
first off to get to the fog lights easier way if ur want to do ur headlamps to is remove the plastic shroud a few push center clips pull them out and then remove the shroud u'll expose two silver blots on either side of the head lamp housing remove them and a phillips head so u can remove the side marker lamps also they clip together and r clipped in so after u remove the lamps and corners ull have access to ur headlamp/ corner bulbs u take off the ring around the socket and th ebulb comes right out. also if u look down into the bumper where the lampsn sat ull see the harness connected to the fogs just a quick twist and they pull out. thats a bout it prob take u 15 -20 min to pull swap and remount all four bulbs. also given the fact they are halogen bulbs a helpful tip is DON"T TOUCH THE BULB AT ALL!!!!!! ur oil on ur hands will cause them to burn out really quick so use some disposal latex gloves when going to touch the bulbs. when ur done check ur align ment of the beams and ur done. good luck just dont touch the bulbs with dirty gloves or hands they will burn out.
Hey guys,,
Can anyone give me advice on changing the head light bulbs on a z24 2001? I tried doing as described above but i got stuck at one point ... I wasn't able to get past the two silver bolts. Once I removed the bolts, the head light seemed to still be attached somewhere. What do u mean by the "philips head", maybe that is my problem??
Please let me know when you have a minute.
Thanks
