so out of no where my service light comes on so i stop turn off the car start it again and its gone then it happens again so i used a code reader and there is no trouble codes . so turn off the car and it comes back then i notice that one head light is not as bright as the other so i figure must be a bad bulb so i turn the car off again the service light is gone and the lights both work . so i buy new head lights and no service light comes on after i put them in . the next day im drivin around and the service light comes on again and one headlight looks like its on DRL and the other is normal but if you shut the car off they work normally for a while till the service light comes on . these are brand new headlights does some one know what the problem is i checked the fuse panel and everything is fine
I would start with the grounds. Bad grounds can cause some weird problems.
"The Blue Bullet"
"bad grounds" where? could you maybe be more specific or explain a little more
