high idle - Maintenance and Repair Forum
high idle
Tuesday, August 29, 2006 10:33 AM
when i start my car it normally idles at 900rpm but when i hit the throttle it will only return to 1500rpm but when i press down on the throttle shaft it goes back down to 900rpm but the shaft does not move.
Any thoughts on what this could be i aready cleaned the butterfly and lubed the shaft
Re: high idle
Tuesday, August 29, 2006 10:47 AM
Try testing your tps.
'96 Cavalier Good ol' Pushrod 2.2
-24X,000 miles on factory build
-Some oil loss between changes, me thinks it be rings.
Re: high idle
Wednesday, August 30, 2006 6:22 AM
how do you test the tps?
