Is there any way to get around this problem w/o paying $80 for a new sensor? If there is a way will it still pass smog? Thanks in advance.
Well you could try the O2 simulator if that is what this code is refering to.  Not sure if it will pass the smog test though.
02 sim, hptuners, or u do the spark plug defouler trick
I read about the spark plug defouler but wasn't able to find it in the search. Could some one post the link. Also, if the sensor is bad how does pulling it out of the airstream fix the code?
