diagnosis - Maintenance and Repair Forum
diagnosis
Tuesday, August 01, 2006 12:35 PM
been working on the car and drove it to work today after lunch. i had forgotten to plug the sensor on the intake so i stopped halfway there and plugged that out but its still acting off. it idles at around 500. the shifts are quick and jerky and the traction system is off. im wondering if there is a fuse that could be the culprit. (cant check till after work) or if i maybe have something unplugged?
Re: diagnosis
Tuesday, August 01, 2006 2:13 PM
Reset the comp, disconnect the batt for 5 mins, that should work. Btw, look real carefully at the plug itself, its a chincy part and has the tendancy or breaking easly.
Re: diagnosis
Tuesday, August 01, 2006 3:39 PM
im good. just guess it took a bit longer to reset then i thought it would. went out to the car after work and everything concerning that was ok.
Re: diagnosis
Tuesday, August 01, 2006 9:35 PM
ya, if u plugged it back in while it was still running, it's not gonna reset until u turn the car off and back on again
