coolant leak help!! - Maintenance and Repair Forum
coolant leak help!!
Friday, May 19, 2006 6:45 AM
My car is leaking coolant pretty badly I have to add some every other day or so.I've taken it to two different dealerships and they said that they couldn't find a leak. It looks like its coming out of the overflow?The car will sometime run at 3/4 temp but most the time the temp is normal.Somebody please help!!!
Re: coolant leak help!!
Friday, May 19, 2006 7:06 AM
I had this problem on my Cav a couple years ago. Turns out I had a tiny hole in the radiator, and it only leaked when the car was running because of the added pressure. So I had to yank the radiator out (pita), and took it to a dude that welded it.
Rob
Sold 2/2/05
Friday, May 19, 2006 7:43 AM
Its leaking somewhere on the right side of the car.There's coolant in the engine compartment so I think it coming from somewhere up high.
Friday, May 19, 2006 11:17 AM
Try squeezing one of the hoses rapidly, with gloves on, with the car at operating temperature but not RUNNING.
This sudden increase in pressure is sometimes enough to pinpoint a leak.
Alont
Friday, May 19, 2006 12:21 PM
you might also want to (carefully) look for leaks while the car is running and at operating temp. just don't touch anything!
Desert Tuners
