My friends j's Low beam dont work.... - Maintenance and Repair Forum
Saturday, April 08, 2006 6:08 PM
the high beam works but low beam don't.... and the service light is on... what could be the problem??
Re: My friends j's Low beam dont work....
Saturday, April 08, 2006 6:28 PM
might be the headlight switch, i had the one on my sunfire go a few times and that would happen, high beams but no lows
The term 'stock' is COMPLETELY relative...
Saturday, April 08, 2006 7:36 PM
What year is your car and how many miles does it have?
Saturday, April 08, 2006 9:34 PM
its a 2002 4 door 2.2 and it has i think 42 kms on it
Sunday, April 09, 2006 10:50 AM
Question before jumping to conclusions, Does your headlights blink really quickly for a few seconds when your drl's should turn on when you drive?
If it does, replace your headlight bulbs. That will fix it. Your DRLs or run on your passanger side.
Sunday, April 09, 2006 12:30 PM
yup they blink really fast then they cut off.... so if he canges the blubs he should be good?? or should he disable his drl??
Sunday, April 09, 2006 5:06 PM
Replace the bulbs would be easier. Im not sure if you disable the DRl's would fix it. When ever a light like that flickers on and off really fast, that usually means a light is burnt out. Just an FYI.
dan
Sunday, April 09, 2006 6:56 PM
but it happens every time he turns his car on, and also his high beams work...
Sunday, April 09, 2006 7:11 PM
could still mean his Low Beams are out, remember they are dual filament bulbs, to one filament is burned out and the other isn't. Obvisouly you use Low Beams more than High Beams
Go Premium, it builds character!
Sunday, April 09, 2006 8:37 PM
could also have a corroded splice behind the washer jug.....seen that more than a few times....but replace the bulbs first befor digging around in the harness
Monday, April 10, 2006 9:24 AM
haron wrote:but it happens every time he turns his car on, and also his high beams work...
I bet you 5 e cookies its the bulbs them selves.
Monday, April 10, 2006 12:14 PM
^^^^^^^^^^Dang, beat me to it!
Yeah the headlight bulb is prob. out
'02 J-bodies use a 9007 headlight bulb.
Monday, April 10, 2006 5:34 PM
lol yea its the blub, he got cheap walmart ones in. i told him not to cheap out! but NOOO, thanks for the help!
